주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
질문 마감됨
iPhone keeps crashing (iOS6, BB 05.13.04, unlocked with Ultrasn0w)
Hi!
I've got an iPhone 3GS, new bootrom, running iOS 6. It is jailbroken with redsn0w, has the 05.13.04 baseband and is unlocked with Ultrasn0w & Ultrasn0w fixer for iOS 6! When it had iOS 5 running on it i upgraded the baseband to 06.15.00 to unlock it. It had some crashes, but really rare. Now, after downgrading the baseband to 05.13.04 and updating to iOS 6, it keeps crashing while making phonecalls or using apps longer than a few minutes. Now, since it has the new bootrom, it has a tethered jailbreak, so i'm screwed if i'm not at home when it crashes once again.
Does anyone know this kind of problem ?? I'm kinda freaking out here !!
Greetings,
Caspar
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Is the main reason of you to jailbreak is to unlock your phone so you can use with other networks? If it is then there are services on ebay that provide unlocking for 14 pounds. I am in the UK. Write back with comments.
John: Yes, unfortunately it is! The phone is locked on orange Austria and i'm using it with 3 AT. So, do you think it's possible to unlock an austrian device with a british unlockservice??
Dakenson: Ultrasn0w and Ultrasn0w fixer is everything I installed. Yeah I use the just boot many times a day! ;-) Anyway, thanks, I hope I'll find a way to factory unlock it.
댓글 달기
답변 2개
선택된 답변
If you installed apps or tweaks from Cydia it's probable that one of them is causing the issue (like Activator) as it has not been tested and edited to support iOS 6.
Also, the iOS 6 jailbrek is tethered, so you must connect your iPhone to redsn0w and click on extras>just boot in order for it to boot properly, you must do this every time you want to turn off or reboot your device.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
hi,
as it is a iphone 3gs and i think its older than 2 years, i would suggest to go to an orange shop and let it officially unlock there. it costs 50 euros.
nice greetings
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 4,399
