주요 콘텐츠로 건너뛰기
모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
581 질문 전체 보기
Possible to install a Retina Display on an Early 2011 unibody MacBook?
My early 2011 unibody Macbook pro 15" LCD broke.
While I am now researching how to fix it by myself, it came to my mind: is it possible to install a Retina Display on it?
What would make it possible? And what wouldn't?
Many thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Unfortunately, the simple answer is no. The graphics card would have issues running the display if you were even able to instal it. The Retina display MacBook Pro also has different connectors and dimensions then the regular Macbook Pro and therefore not fit and not connect. The firmware for you computer will also not scale the resolution and render properly so you would have a 1440 x 900 resolution displaying on a 2880 x 1800 display which would only take up 1/4 of the display. I wish it were possible but it just isn't. You will have to replace it with a regular 15" 2011 panel.
Hope this Helps
해당 답변은 도움이 되었습니까?
점수 2
2 댓글:
and what about replacing it with display with slightly more pixels (1600x900, i guess) with anti-glare layer? does it fix and how difficult this operation is
personally wouldn't risk it I saw someone plug in a wrong screen into MacBook pro heard a fizzle and a pop and both logic board and lcd cables were damaged never had video though lcd again had to run on external screen all the time after that
댓글 달기
귀하의 답변을 추가하세요
marcelpace 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 9,397
