My screen is not receptive to touch in lower left corner
After replacing the battery, my screen is not receptive to touch in the lower left-hand corner. This is problematic in texting, as I cannot move between the qwerty keyboard and the emoticons. In order to access the qwerty keyboard, I have to rotate the phone to the landscape view specifically to the right because that forces the 123/ABC button to the lower-right hand corner. Did I mess something up while I was changing the battery? BTW....the new battery works great.
좋은 질문 입니까?
댓글 2개
Ok...I opened the phone, looked to see if any of the connections were loose..which there didn't appear to be but when I closed the phone and turned it on it was functioning properly. All is good...battery is holding a charge and the screen is responsive in all areas. Thanks!
mitchy65 의
The exact same scenario happened to me but mine was the bottom right screen. I just under did the connecters and redid them it took like 5 or 6 times till the screen worked again.
John Luc 의
