주요 콘텐츠로 건너뛰기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서
140 질문 전체 보기
Replacement of original 1.66 Mhz CPU
Hi @ all,
Thanks to the great guides on this side I managed to replace 80 GB hard drive by 500 GB and increased the RAM to 2 GB. Thanks to all of the testers and writers!
Now I have the chance for possibly great deal, getting the T7500 CPU (2.2 Ghz) for a less than reasonable price. Looking at the Intel specs just bus speed (800 to original 667) and the voltages slightly differ. I guess bus speed doesn't matter because it will be limited to the systems 667.
Will the T7500 CPU work in this Mini model? Quick reply highly appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Apple A1176 produced models:
Mac mini 1.50GHz Core Solo T1200 (MA205LL/A, A1176, Macmini1,1) - Early 2006
Mac mini 1.50GHz Core Solo T1200 (MA206LL/A, A1176, Macmini1,1) - Early 2006
Mac mini 1.66GHz Core Duo T2300 (MA206LL/A, A1176, Macmini1,1) - Early 2006
Mac mini 1.66GHz Core Duo T2300 (MA607LL/A, A1176, Macmini1,1) - Mid 2006
Mac mini 1.83GHz Core Duo T2400 (MA608LL/A, A1176, Macmini1,1) - Mid 2006
Mac mini 1.83GHz Core 2 Duo T5600 (MB138LL/A, A1176, Macmini2,1) - Mid 2007
Mac mini 2.00GHz Core 2 Duo T7200 (MB139LL/A, A1176, Macmini2,1) - Mid 2007
CPU “Socket M” also supports these 667 Mhz FSB processors:
1.73Ghz Core 2 Duo T5300
2.13Ghz Core 2 Duo T7400
2.33Ghz Core 2 Duo T7600
I have had every single version of these processors working in A1176 platform. The 1,1 model can be flashed to 2,1 and any processor used.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
가장 유용한 답변
ok - here we go.
since we've had this topic yesterday - i can say somethig about that
the t7500 is a socket P (479) - the mini needs a Socket M (478)CPU (7200, 7400, 7600)
even if the cpu would fitted with an adaptor - it woul only have around 2ghz - and that would be to much trouble for this little gain.
i paid 80 usd for a almost new mini itx board - including the power supply, riser card and a t7400 cpu
thats 25% off the regular used ebay price for the cpu alone - so maybe you should look aout for some itx bundles - they are sometimes realy cheap to get.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Timpetou 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,784
