주요 콘텐츠로 건너뛰기
A compact digital camera released 09/15/2005.
12 질문 전체 보기
sd card won't come out of camera
The sd card is stuck in the camera. Any ideas as to how to get it out. Have tried tweezers and it still won't come out keep pushing but no luck getting it to pop out as it normally does.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi, I think the spring mechanism might be jammed. What u need to do is push the sd card down gently and gently turn the card, and try to pull the card out. The key is patience and be gentle. Write back on what u did. Good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
thanks it worked
댓글 달기
I have the same issue & I got its solution later. So i can help you.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Molly 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 2,024
