주요 콘텐츠로 건너뛰기
2006 중반기/ 모델 번호 A1181 / 검정 또는 흰색 케이스 / 1.83 or 2.0 GHz Intel Core Duo 프로세서.
418 질문 전체 보기
Cracked casing on back of laptop
Hello, I dropped my Macbook and unfortunately have cracked the back of the laptop on the casing (just above where the battery compartment is located. The computer still works but I am worried about dust and moisture getting inside the computer. Do you sell a casing and is this easy to fix or quite complicated?
Thanks,
Dan Griffith
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
I agree, it's a difficult procedure, requiring transplanting pretty much all of the MacBook's components to another bottom casing. Although, it is do-able, and iFixit has a guide, so you can see what you're getting into. The bottom casing can be purchased on eBay and probably iFixit for a fairly reasonable price, however there are a couple different versions, so it's important to make sure you get the Core Duo bottom casing and not the Core 2 Duo casing.
If you decide to live with the casing as-is, perhaps some heavy duty clear plastic tape over the cracks would alleviate the concern about dust and moisture.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
the case is not dust or moisture tight anyway - so not much has changed. I agree with ^ that take the crack and live with it for the time being is the most efficient solution
댓글 달기
There doesn't seem to be the part itself for sale but here's the guide for installing it (It's rated "Difficult")
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
dan02 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 906
