주요 콘텐츠로 건너뛰기
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 질문 전체 보기
질문 마감됨
starter on 96 camry where ia it
just replaced water pump and all belts. now car will not crank. tried jumping it no good. battery has plenty spark on jumper cables.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
all lights bells and whistles are working
Do your head lights go dim when you try to crank it over?
댓글 달기
답변 1개
선택된 답변
jeanette beasley, could be a bad solenoid as well as bad fuse. If you are looking for starter etc, check on here for a great tutorial. if you have trouble finding it with those pictures, it should be on the driver side of the engine bay over the the transmission. Easiest way to find it is follow the big red cable from your battery, it should lead to the starter. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,549
