iPhone 3G doesn't charge (dead fuse)
Hello,
I have a iPhone 3G that does not charge. I checked the charging fuse and it seems like it's gone, so I put a small bended paper clip to short-circuit it and plugged the usb to my pc.
Nothing happened after 5 minutes...
how can I check the dock connector and if the current is arriving to the logic board?
좋은 질문 입니까?
점수
0
Did you check for power on your battery connectors? Paperclip? Darn, that space is so small, how did you manage that:-)? Are you sure you did not short anything else out. A small dab of solder or a circuit writer pen would have been plenty :-)
oldturkey03 의
I did not short anything, however now I have put a small copper wire around it; didn't think about the circuit writer pen... I don't have one... Would a normal pencil do the job?
Can you tell me also how to check the dock connector?
I also tried to measure the voltage on the dock connector where you can see the > sign (and the other pin of the tester touching the chassis)
I don't know if it is the right point to test
It shows 0v with the cable unplugged and 3.7v with the cable plugged
Jacopo Scarpellini 의
Sorry, a regular pencil does not work. Anyhow, check on here http://pinouts.ru/PortableDevices/ipod_p... for the pinout. It should help you when you measure at your dock connector. Do you have any experience with reading schematics?
oldturkey03 의
I don't think that one is useful, since I don't know which inside contact correspond to the pin outside
Today I got a working 3G; I tried to put the logic board into this one and it still does not work; it doesn't turn on, so I think it's something about the logic board
