메인 콘텐츠로 스킵하기
Model A1311 / Mid 2010 / 3.06 및 3.2 GHz Core i3 or 3.6 GHz Core i5 프로세서
315 질문 전체 보기
Colored vertical lines on monitor
Hi.
I already read a post about a similar problem, but my case is slightly different...
My monitor suddenly shows colored vertical stripes, going from top to bottom (only half of the top Menu Bar is correctly displayed). The stripes are not fixed, they vary in width and colour depending on what is displayed. An attached monitor set as primary works fine.
I have been told it could be either the display or the graphic card (or hopefully just something concerning the connection between the two).
I would like to open my iMac with the help of one of the great guides I found here, but I don't really know what I am looking for... can you help me? Is it really a problem I can fix myself?
I add a pic of my monitor, maybe it can help...
http://cl.ly/L5TY
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
Send me an email. it's in my profile. Might have something that can help you clarify those answers.
의 답변
의견 추가하세요
3개의 답변
선택된 해법
Since you say that an external monitor works fine, there is no problem with your graphics card.
This narrows it down to either the display or the display data cable. I would recommend changing the cable first, as it costs quite a bit less. Here is a site that sells it: link. The picture on your screen actually reminds me of the TiBook G4 displays. The hinges would break, crush the display data cables, and cause the display to show random vertical stripes.
If that doesn't work, then change the display.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Forgive the stupid question...but I am reading the guide explaining how to remove the GPU card: the cable I should replace is the one mentioned in Step 12, right? (GPU guide) Do I have to follow the whole guide in order to replace it, or is it possible to disconnect the cable without having to take the logic board out?
의 답변
Andrew, Jacks answer was correct you don't have a Graphics Processor Unit (GPU) problem.
의 답변
You don't need to take out the logic board.
의 답변
의견 추가하세요
I would start here with running Apple Hardware Test to test things out. If you had a GPU problem it would tell you. AHT can't test the entire display system so if it passes don't fret.
I agree with Jack here, you likely have a cable or LCD display unit issue. So I'm not sure why you're pulling the GPU out? All I would do here is pull the Sync & data cables out and reseat them back to see if just reseating them fixed things. Then I would replace the vertical sync cable then the data to see if they were bad. If I saw no improvement its got to be the display it's self.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Thank you for your answer, but the reason I am referring to that guide is that I do not know which cable I should replace!
I do not want to pull the GPU out if I do not have to! but then please tell me which guide I should follow
의 답변
의견 추가하세요
hey AndrewB I'm having the same issue on my iMac, I connected it to an external monitor and it worked, I see your post is from 2012 so I wan to ask if you could fixed it and what was the problem..thank you!
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
AndrewB 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 32
지난 30일: 143
전체 시간: 9,749
