주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
질문 마감됨
[SOLVED] LED light always on, what could be the reason?
My LED light on my iPhone 4S stay always on. I try to re-initialyze the phone without success on LED light (the camera flash in fact).
I have all updates done, and it doesn't change anything, even when I turn off the phone.
Otherwise it works well. The phone isn't cracked or breached.
Any solution ?
Thanks for your time !
Update
Testing with parts of my wife's iPhone... and it's working....
No problems with connectors in both parts
So I have to change for new part....
Final Update
Replacing Rear camera quite easily... and it works well now.
Thank you all for your disponibility !
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I will check the camera to see if it works.... Maybe I have to change these ?
댓글 달기
답변 4개
선택된 답변
Interesting problem, I have had 1 phone in my shop with this exact problem and it turned out to be corrosion on the motherboard (water damage) , I would disassemble your phone and inspect all parts and treat any corroded spots with alcohol and a toothbrush, good luck. iPhone 4S Teardown
해당 답변은 도움이 되었습니까?
점수 1
댓글 9개:
Thanks for your quick answer, but I'm sure that I never had water damage.
I'll try to disassemble it and inspect it... Wait and See !
Thanks I would love to hear what you find out.
Nothing special found after inspection of my iPhone...
No corrosion, all connectors OK, the liquid indicator is white....
Maybe it is an hardware issue ?
Yes, I would try replacing the Camera-led next, they are cheap, if that doesn't work you should try restoring it, several times if necessary, I know that's a pain but I have had to do that several times to make a camera work correctly, something else, if you don't have a flashlight app I would get one and see if you can turn the led off with the app open, keep us posted, good luck !
Hi ! It doesn't change anything with an App with flash, like iTorch.
I can turn on and off the light with the App. When closing the App, the symptoms are the same....
댓글 4개 더보기
댓글 달기
Last time I had a wet phone with this issue I cleaned the connectors for the camera and it worked fine afterwards.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yes but mine wasn't wet at all !
댓글 달기
It is most likely a bad connection of the camera. Simply take off the rear plate and disconnect/reconnect the camera and that will fix it. GOOD LUCK!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Generally this is related to water damage. Replacing the camera might work, but more often when I see this finding corrosion on the board and cleaning it is what solves the issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 35,712
