주요 콘텐츠로 건너뛰기
11인치 디스플레이가 장착된 MacBook Air 모델에 대한 수리 안내서, 지원 및 문제 해결 정보입니다.
929 질문 전체 보기
Do you have any suggestions on removing stripped screws?
I have stripped three of the 1.5mm screws securing my trackpad to the top case. Despite applying sufficient pressure, the #00 screwdriver I was supplied with stripped the screw heads like butter.
My question is, does anybody have any suggestions for removing stripped screws? My first thought would be using long nosed pliers to grip the edges of the screws, then rotate.
As an aside, does anyone have a source for obtaining these screws? I would obviously need replacements.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
If you have a multi-tool with a carbide blade or a grider with a thin cutting blade. Cut a straight line across the head and use a flat head bit on a drill to reverse it out. If that doesnt work, cut the head off and drill it out. If it is a threaded hole, tap the hole with a tapping kit and get a new bolt to match the size. Hope it helps.
댓글 달기
답변 3개
선택된 답변
Hi Mark, I've had good luck with this list of the 12 best ways to remove stripped screws (the rubber band trick will probably work well here).
If none of those work, iFixit also has a Precision Screw Extraction Kit that should be able to get those out.
Precision Screw Extractor Set 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Heat up with heat gun carefully. If you are afraid of using heat gun which is extremely dangerous since it may destroy other nearby components, you can use soldering iron. When it's very hot, use medium size players and unscrew anti clockwise. It should come out.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I used a pair of needle nose pliers to extract 4 stripped screws. And because I'm too impatient to wait for a order of new screws to be shipped, I installed the new trackpad using this same method =)
Oh, and I did get out 1 screw which I didn't manage to completely strip yet, using the rubber band method that was mentioned.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mark 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 43,323
