주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
405 질문 전체 보기
How do I replace the LCD screen glass?
I have a MacBook Pro A1286 and the LCD is fine but the screen glass is cracked. I can find it on eBay relatively cheap but how do I take off the cracked screen glass? Is it with the heavy duty suction cups?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
You can find the guide to remove the LCD here, all you have to do is stop after you remove the glass though. Follow up until step 29 and do not continue to step 30. At this point, you will just need to attach the new piece of glass to the housing with double sided 3M tape, the heavy duty kind. I is also best of you clean off the residue left behind by the last piece of glass, it will prevent the glass from detaching in the future.
Guide:
MacBook Pro 15" Unibody Mid 2010 LCD Replacement
hope this Helps
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
MacQue 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,214
