주요 콘텐츠로 건너뛰기
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
429 질문 전체 보기
The lid will not come off
i have tried everything to get the lid off the playstation 3 slim and will not come off at all. what should i do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 4개
가장 유용한 답변
I don't know why no one will answer this question clearly, this is the third forum I've seen without it. There is a HIDDEN screw, even sneakier than the ones under the black square pieces - it's underneath a BLACK STICKER WITH TEXT ON IT, right on the bottom of the PS3, hiding in plain sight. You have to PEEL OFF THE BLACK STICKER to reveal another of those black plastic squares, which after removed will reveal the final screw. (caps for clarity)
해당 답변은 도움이 되었습니까?
점수 6
8 댓글:
I've seen "remove the seal", but that doesn't convey what you're looking for. Again, on the bottom of the PS3 where all the other screws were, close to the center, there's a black sticker with text on it. You have to peel that sucker off, and voila. You're not crazy, I'd guess probably 82% of people fall for this like I did, because it's a total curveball. Like a trapdoor under a rug.
@Chris B thanks man you are a life saver
God Bless you Chris frustrated i was about to go hard way and most defiantly damage
Thank you so much. I was about to break this $@$* even more, lol. You're the man! XO
3에 댓글 더 나타내기
댓글 달기
Make sure all screws are taken out. There is one that is under the seal. That one is usually the one that people forget to take out.
해당 답변은 도움이 되었습니까?
점수 2
2 댓글:
i took out all the screws even the software but the lid would come off from the front where you insert the disc only the back of it would come off. any recommendations please?
Same nothing worked
댓글 달기
You prob missed a screw. Look at the guide on here and make sure you did it correctly.
Or just jerk it real hard. It'll come off
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
i did that i have used a tool to ply the front top lid off of the PlayStation and it will not come off at all
any idea what i can still do?
댓글 달기
I hade the same problem There's one more hidden screw found out the hard way
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
marioehusari 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 35
30일 전: 101
전체 시간: 6,594
