Why can't I play any games?
My Xbox seems to not be working. Every time I put a game or disk in,it reads it then,it says "Open Tray". If like nothing was in there. Do you know how to solve my problem?
좋은 질문 입니까?
좋은 질문 입니까?
It looks like your optical drive is damaged.
Try this guide-
Xbox 360 S Optical Drive Replacement
OR
It may not be recognizing the optical drive.
해당 답변은 도움이 되었습니까?
Most likely it is a bad laser. This has been the case for 99% of the consoles I have repaired. For a few bucks you can replace the laser. This is the least expensive method to try first.
해당 답변은 도움이 되었습니까?
xbox will not recognize swapped drives. You have to open the drive, extract the original drive's logic board, put it into the new drive. Or do some serious hacking.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 496
