주요 콘텐츠로 건너뛰기
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
109 질문 전체 보기
질문 마감됨
Changing Rear Left Side Tail Lamp
How do I change the Rear Left side Tail lamp?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
가장 유용한 답변
Pop out two plugs inside the tailgate opening and remove the two screws under them, this will allow you to "pop" the taillight assembly loose from the vehicle. Once that is done, you can disconnect the electrical plug to remove it from the vehicle. If you are just replacing the bulbs, you don't have to do that, but it makes it easier. Twist the bulbs you need to replace counter-clockwise to remove them, or move all of the bulbs to the new part if you are replacing the entire assembly.
Installation is the reverse of removal, the link below has a video that shows the process in good detail.
http://www.youtube.com/watch?v=D_LMd9CD7...
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 4,486
