How to replace dash lights for clock and manual climate controls
The light bulbs that illuminate the climate control buttons, clock and moonroof switch are not working. How do I replace them?
좋은 질문 입니까?
좋은 질문 입니까?
Here's good write-up I found to replace the instrument cluster lights, hope it helps!
1 - Unscrew the two screws at the top of the underside of the instrument panel trim cover using a screwdriver.
2 - Pull the instrument panel trim off of the cluster assembly.
3 - Unscrew the four screws from the instrument cluster that hold the cluster assembly in place.
4 - Slide the cluster assembly forward.
5 - Unplug the electrical connectors from the back of the instrument cluster.
6 - Turn the cluster assembly over and locate the bulbs that need replacing.
7 - Turn the instrument cluster light bulb counter-clockwise to unlock it from the back of the cluster assembly.
8 - Pull the bulb out of the back of the instrument cluster and insert a new bulb. Then, turn the bulb clockwise to lock it into the instrument cluster.
9 - Reassemble the dash by reconnecting the electrical connectors to the back of the cluster and securing the cluster and trim with the factory retaining screws.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 2,258
