주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
earpiece not working but loudspeaker or earbuds do
iPhone 4- Headphones or earbuds still work when plugged in. Loudspeaker at base works if speakerphone chosen. Earpiece has suddenly stopped working. Had been using headphones just prior. Is this a function of the headphone jack not releasing the sound circuit back to the earpiece or the earpiece itself just died? So do I need a headphone jack assembly or just an earpiece speaker?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
my@iphone 6+ ear piece side is not working but d speaker does pls what can i do
댓글 달기
답변 11개
가장 유용한 답변
Disclaimer! If my troubleshooting steps make the device worst then it already is, I am not...i repeat, I will not be responsible for it. So use these steps at your OWN RISK!:
I work as advance tech special for a wireless company. What normally work for that specific device is:
1) Plug a headphone into the device
2) Make a test call and make sure you are able to ear call on headphone
3) Toggle the Speaker on & off and make sure you are able to hear call on the headphone
4) Toggle Speaker OFF
5) Remove headphone
6) You should be able to hear from earpiece now.
7) If all fails - Restore via iTunes!
By: The Subliminal Poet (follow me on twitter, fb, and instagram)
해당 답변은 도움이 되었습니까?
점수 8
댓글 6개:
This worked perfectly first time I tried it. Phone is doing it again but cure doesn't seem to be working :(
Just saved me a trip to Apple! Thank you!!
Awesome !!! its worked perfectly...now its working... thank you!!!!
Worked for me. Thanks
Len D
Great!!! Worked for iPhone 6s plus. Thank You!
댓글 1개 더보기
댓글 달기
Usually that would be only the earpiece, that's where I would start, a link to the part, https://www.gounlock.com/details.php?ite..., a guide, iPhone 4 Earpiece Speaker Replacement, good luck, If this Answer is helpful please remember to return and mark it Accepted
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Well, it was not the earpiece. Ordered one but through trial and error determined that by holding the phone upside-down and re-inserting the headphone jack several times I could get the earpiece to work again eventually. As long as I didn't use the headphones or earbuds the earpiece worked for days. It always failed right after the headphones were unplugged. Ordered the headphone jack and volume control cable and tore the whole thing apart to replace it. Seems to be working fine now.... certainly don't want to do that again anytime soon!!
Since I had the phone apart I replaced my funky Dock Connector too.
Rick
When absolutely none of this worked for me I took a screwdriver and whacked the !&&* out of the top of my phone. NOW IT WORKS! Probably will not work for most people though. Of course I already reset my phone losing my settings and my purchased ringtones forever. I HATE Apple!
댓글 달기
Koo.. It worked for me..
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
This worked for me ..... Your awesome dude!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This worked for me. Thank you so much!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thankyou sooooooooooo much!
I tried all the other solutions i found online, compressed air into the headphone socket, pushing the jack in and out, squeezing the speaker face and even a restore.
I was pretty much ready to start crying when i found this!
Thanks again you wonderful genius! :D
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Ok so my outter speaker works perfectly fine, but the ear piece speaker doesn't work properly, it fries and make baffling sounds, when I make and receive calls I have changed my speaker, I have updated to 8.1.1, also restore my phone. But it works perfectly fine when I use viber and Magic jack, or even Facebook messenger so what's the problem??
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Try switching to Android... That's always worked for me.. Just saying, lol.
vviii
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
First restart your device, then blow the headphone jack and plug your headphone, listen to something first , than unplug it, and test it out
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
dear sir i cant hear sound during call but hear sound when i on the speaker kindly help me about this problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My phone earpiece not working I don't know why
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
One this should be another question, and 2 did you even read anything in this post?
댓글 달기
귀하의 답변을 추가하세요
ramosel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 85,678
