주요 콘텐츠로 건너뛰기
질문 마감됨
My netbook won't boot up what can I do to fix it?
I have an asus Eee Pc 1005HAB Netbook and as soon as i turn it on it says " Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key". Why is it saying this and what do i need to do to fix it so i can use it again?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
hi,
Sounds like its not finding the HD (harddrive) to boot from.
During the post (startup) when you see a lot of white text on the black background can you see on the screen if the Eee can see the HD.
These can boot from a USB drvice, have you anything plugged in to the USB?
Have you changed the boot order?
Do you have a USB DVD/CD reader?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I'm having the same problem with my acer netbook, I might have changed some things with out knowing what I was doing.
Is there a way to restore my netbook without it costing an arm and a leg.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,017
