주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2191 질문 전체 보기
질문 마감됨
iPhone 4s won't charge
Hi!
I have a iPhone 4s that took a swim. Everything seems to be working perfectly, except it wont charge.
I have replaced the dock-connector and the battery, but nothing has turned out working. The battery percentage keeps dropping as i write.
The charging symbol shows when the cable is plugged, but the phone doesn't charge. It is not recognized by itunes either.
However, if i plug the phone into a speaker-dock, music starts playing (from the dock). The microphone, loudspeaker and homebutton is working aswell, so i cant really figure out what the problem is. Is there any other parts i should try to replace?`or is there any other method i should try?
Any suggestions are welcome! i really need this to be fixed
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
You need to disassemble your phone and treat the logic board for water damage, here is a guide for treatment on a 3G but use these methods on your 4,Repairing iPhone Liquid Damage and here is a guide to teardown your 4, iPhone 4S Teardown, good luck, If this Answer is helpful please remember to return and mark it Accepted.
iPhone 이미지
안내서
난이도:
어려움
1 - 2 hours
iPhone 4S 이미지
안내서
iPhone 4S Teardown
난이도:
운영
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 4,714
