주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
544 질문 전체 보기
Why is my CPU fan running full speed?
I bought a used iMac and the CPU fan is on full speed, all the time. As soon as the computer boot chime is heard it starts up and stays running full speed. Using guides here I took the computer apart and discovered it is missing the LCD temp sensor and cable. Would this cause the full speed CPU fan, or is there a good chance there may be additional problems with the logic board even if I replace the missing sensor?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
The missing sensor would certainly cause the fan to run at full speed. If the computer seems to run fine besides the fan, there is no reason to suspect the logic board. The main question would be way the sensor is missing in the first place. I'd ask the original owner about it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
Here's the guide for replacing the ambient sensor which may help: iMac Intel 20" EMC 2133 and 2210 Ambient Temperature Sensor Replacement
Thanks for the response. I ordered a used sensor and sensor cable. Hopefully that solves it. The computer works perfect other than this issue, I am actually using it to post this comment.
The guy who sold it too me bought it from iFixiMac who sells iMacs on eBay. Based on the conversations I have had with the guy I bought it from, I am certain he never took it apart or had anything to do with the issues with it. I am pretty confident iFixiMacs took it apart and likely took the part to fix another less scratched up iMac. What also is concerning is iFixiMacs then sold it via craigslist, not eBay, a method with no buyer security, further reinforcing the idea they just wanted it off their hands.
Consider getting a SquareTrade warranty on it. I've had good experiences on the two claims I have filed with them.
I bought a used LCD temp sensor and cable for $15. Installed them today and the computer now works 100%. Thanks for the info and confidence to fix this.
Glad I could help.
댓글 달기
귀하의 답변을 추가하세요
Eric Drust 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,490
