5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2996 질문 전체 보기
Back camera doesn't work after screen replacement
I replaced the screen of my iPhone 4S. I've done many before, and I'm good at it, I would like to think.
However, when I tried to go onto the camera it just loads the shutter image and wont go any further. The controls at the bottom flash a few times, and some times it will go back to the apple logo and then onto the lock screen. (Not like a reboot, it only takes about 8 seconds)
I ordered a new camera and replaced it, still the same. I've even swapped it for a one I know works and still the same.
Any ideas?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
2개의 답변
선택된 해법
I have seen this once and fixed it by restoring the phone several times, that's all I have to offer and hope you get it fixed, good luck, If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Can you expand? How can a hardware issue be repaired by a software method?
의 답변
The way I read your question it sounds like you have ruled out hardware, and your symptoms are the same as the one that I fixed with the restore, unless I'm reading your question wrong,,,, when I was stumped by this I called Apple support and they are who told me to restore, and it did finally work after numerous restores,
의 답변
의견 추가하세요
i have the same problem, I've had it for a couple of months now, never found any solution to this. I think it's a motherboard problem, where you connect the camera.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Jamie Simpson 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,344
