주요 콘텐츠로 건너뛰기
iMac은 Apple의 올인원 데스크탑 컴퓨터 라인입니다.
8379 질문 전체 보기
Cleaning the Mac's innards when you are replacing the HD
Plan to exchange original HD for 2TB one. When at it, noticed quite some dust in/on fans and other places. Once read (do not remember where) that it is unwise to vacuumclean the innards. Why?
I have ESD-safe brushes and other gear, will mechanically block the fans (so they cannot act as windmill generator) and use the VC on its lowest powersetting and will maintain at least a 10 cm or 4 inch distance between hose-intake and innards. Still unwise?
Greetings from continental Europe.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Vacuums in-fact create a static charge! The air sucked in at the nozzle creates a mini Van de Graaff generator within the air stream between the different air pressures. - As Machead stated use Can'ed Air to blow the dust and junk away. Scrubbing with a soft artist brush (being careful not to snag any parts with the brush) to help loosen the dust is also a good idea.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Parts can be knocked, torn, or sucked off the board with careless use of a vacuum, that's why blowing is recommended. With your attention to care you should suffer no ill effects.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
OK and thanks for your thoughts and comments Dan and machead3.
F.H.
댓글 달기
귀하의 답변을 추가하세요
Feike Hoogenbos 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,081
