주요 콘텐츠로 건너뛰기
2.26 또는 2.4 GHz / 흰색 플라스틱 유니바디 인클로저
646 질문 전체 보기
질문 마감됨
How to disable headphone jack?
I have had this optical-out switch problem for over a year now (red light showing out of headphone jack). Ive tried everything to fix it. Even put a bit of Rubbing alcohol in it to see if it might be dirt that is clogged inside.
Is there a way to permanently disable the headphone Jack or manually switch the audio like you can on a PC?
I want to fix it before i sell the machine.
Any help would appreciated
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
The red light means your digital audio out has switched on. You can insert a plastic toothpick in the hole and try and switch it off. The switch should be at the 3 o'clock position and go towards the 6 o'clock position. Some people also have had luck inserting their headphone jack and pulling out a few times. Another recent report was that inserting the headphone jack and turning it clockwise in the hole helped.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I know of no "magic fix" - what you can do as a work around is use USB audio through a USB audio Adaptor (USB audio works separate from analog)... it would have a working line/headphone jack.
Just tell the potential buyer about the problem and it's solution.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 5,130
