주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
243 질문 전체 보기
Super Slim HDD in a Retina Pro?
I just got the new 13 retina and I looked at the teardown and it was noted that there is a big space below the trackpad where the normal ssd is. Would I be able to put in a super slim regular hard drive? The ssd does not have enough space for me, but the rest of the computer is awesome!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Manta(만타) 드라이버 키트
112 bits for every fix.
Upgrade Your Toolbox
Manta(만타) 드라이버 키트
답변 1개
선택된 해법
I am guessing your MBPr came with the 128GB storage option? It says in the teardown that a 9.5mm HDD just doesn't fit and could possibly fit the 7mm or 5mm but the problem comes in with the cables and mounts. Apple uses proprietary cables that are only used in their flash based storage so even if a super slim drive could fit you would have to work around the additional cords and also how to fasten it securely in the housing. Your best bet is to just upgrade the flash storage with something like the OWC Aura. It is much easier. You are however going to have to pay a premium for that ease. The best part is that if you replace it with flash storage you will still have extremely fast startups and data rates that you just couldn't get with traditional drives.
Here's the link to the OWC Aura:
http://eshop.macsales.com/shop/SSD/OWC/A...
해당 답변은 도움이 되었습니까?
점수 2
댓글:
+ excellent answer and link
의견 추가하세요
귀하의 답변을 추가하십시오
Jake 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,353
