MacBook 13 2.16GHz suddenly shuts off
Hello,
I own a MacBook2,1 with a 2.16GHz Processor (Mid 2007) that shuts off after about 5 minutes. When using a fan control software that speeds the fan up to 6000rpm the system seems to run stable. When increasing the CPU load while the fan is running high the system will shut off at about 62°C. I used 'iStat Menus' to read out the temperatures and 'ExtendedMB+MBproFanControl V1.2' to get control of the fan speed. 'CineBench' helped me getting a high CPU load. After the system shut off it takes several minutes before a reboot may be proceeded successfully. This may be the time it takes to cool down the defective part(s) of the MacBook. It doesn't make a difference if the MacBook runs with battery power or with the external power supply. Here's what I did so far:
- SMC reset
- PRAM reset
- I tried to update the SMC but the system told me that this is not necessary for my computer
- Replaced fan
- Replaced heat pipe with sensors
- Relpaced upper case
- Replaced RAM
- Replaced battery
What else can I do? Any ideas?
좋은 질문 입니까?
