PB G4 Aluminum 12" does not have PRAM Battery?
hi,
i have PowerBook G4 Aluminum 12" that does not work,
and i wonder its PRAM Battery was down.
so, I want to replace the PRAM Battery.
But i can't find a PRAM Battery in PowerBook G4 Aluminum 12".
why? PowerBook G4 Aluminum 12" doesn't have a PRAM Battery?
please help me.
thank you.
shige
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
6개의 답변
선택된 해법
Try resetting the PRAM through Open Firmware:
Boot Mac while simultaneously holding Command+Option+O+F
When at the command prompt type the following:
reset-nvram <Enter>
reset-all <Enter>
The Mac should now reboot into OSX with a reset PRAM.
Also the RAM slot on this machine tends to fail. I would remove the RAM and try rebooting.
The 12" machines do not have PRAM batteries Chris is correct on the 12" not having a battery. Here's Apple article on it: http://support.apple.com/kb/TA25911?view...
해당 답변은 도움이 되었습니까?
점수 5
의견 추가하세요
These machines, just like G3 and G4 iBooks do not use PRAM batteries, they use power from the main battery and a capacitor on the logic board to maintain the clock.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
any reason for the down vote?
의 답변
Just to confirm, They do not have a PRAM battery, just like the iBooks.
의 답변
You are correct---the G4 DVI has a pram battery as do the Aluminum 15" and 17" but not the 12". ralph
의 답변
Confusing Chris, if it has no battery, why would he look online for someone selling them? You might want to edit this one.
의 답변
Done!
의 답변
의견 추가하세요
hi,
Mr. Chris
oh, i didn't guess that don't have PRAM BATT.
My machine only have a capacitor on the logic board.
i understood. thank you.
i guess main BATT is down too, so doesn't work...
Sir mayer,
you say not Command+Option+P+R, but Command+Option+O+F.
Ok, i will try.
thank you so much, every one.
shige, tokyo.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
That will also work.
의 답변
의견 추가하세요
hi,
Chris
I have PowerBook G4 Aluminum 12".. Problem is that, when i charged it fully and then i open bluetooth or playing DVD, sudenly the battery level become very low , showing 1% or 2% charge.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Please start a new question.
의 답변
의견 추가하세요
I have a similar issue.
Does the booting with command option P + R
not work to reset PRAM with this 12" powerbook ?
I had found that on Apple support pages.
thanks
David
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
I need help with my Macbook 13". Sorry to plug it but no one has responded and I'd really appreciate some insight. Thanks!
Upgrade motherboard feasible with later model A1181
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
shige 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 17
전체 시간: 6,854
