Screen flickering when opening cover
I have a HP laptop. When the cover is half opened, the screen stays ok.
When I open it so I actually work with it, it flickers, turns complete white or black.
When pressing at the bottom of the screen, just above the logo, or when pressing the bezel at the bottom the screen is OK.
What could be the issue, how can ifixit?
Could it be an grounding issue?
There is a aluminium foil on the backcover, the screen is on top of some black foam. Should it make a electral contact?
Please advise
좋은 질문 입니까?
댓글 2개
I took the laptop apart and measured the cable. It has no opens. But it could be a crack in the wire.
Also the cable is not a flatcable but soldered single wires with multicores. They are more difficult to crack, but ok..it could be.
Last thing I doubt about the broken cable..when I add pressure on the screen (when it was not apart) the screen worked perfectly. So now I have seen the connection I'm suspecting the connector itsel...or at least the connection between the connector and cable.
I order a cable after I'm sure it's not the connector.
Cable cost me around $10 if I order in US, I'm in Europe...cables varies from $25 to $70
Please correct me if my thinking sucks
Niels 의
Niels did you take a look at the connector? Have your tied to start it up with the display partially disassembled to see if pressure on the connector will fix it. If regular postage from the US to your country is cheaper than $15 I'll send it to you:-)
oldturkey03 의
