주요 콘텐츠로 건너뛰기
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 질문 전체 보기
질문 마감됨
Why does iPad charge slowly (only 4% overnight) after repair?
I replaced the digitizer on my iPad 2 and it has caused some new issues. First, the iPad only charged 4% over night after the replacement. Secondly, the home button is only working intermittently. Lastly, it is randomly resetting itself when I plug it in.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I would check your battery connection and make sure you didn't break or tear any connections or cables. I had a friend whose iPhone wouldn't charge and kept shutting off randomly because the battery wasn't properly connected.
And of course, here is the guide if you need help.
iPad 2 GSM Battery Replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Solution Iphone 4 batter slow charge SOLUTION
Just go to settings > reset > 'reset all settings'
This is the solution to get the Iphone back to normal (quick) charging!! 100% worked for me after anoying 2 weeks of figuring out WHY it charged sooo slow! You won't lose data/contacts. Only WiFi passwords and some basic settings, but this is not a big deal compare to the slow charge problem! Success!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,011
