Model No. A1367 / 8, 16, 32, or 64 GB capacity
1298 질문 전체 보기
Stuck in white screen with broken home button!?
Please help me! One week ago, i jailbroke my ipod and it got stuck in apple logo. and i cant restore it in itunes and also all the solutions i've found needs home button. but my home button is broken... then i tried to fix it by opening the screen of my ipod. only to find out that the home button (color gold inside) is already broken. so i cant fix it. then i tried to restore in itunes and it worked! but the problem is.... the screen is pure white. i tried 10 times restoring it but nothing happens. i jailbroke it again then restore but nothing happens. so my problem is how to get out of white screen with broken home button. and i think theres a wire in the screen that is not properly attached. (my thoughts). so what maybe the problem of this? and how will i fix it? tnx. godbless.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
3개의 답변
선택된 해법
I would pop it open and reseat the LCD connector which you can find in the guide here for replacing the screen for your ipod. Most likely though you will also need to try a hard reset (holding both home button and power button for 10 seconds). So i would order a new home button flex cable and replace it while you are in there. Its very easy to replace and again, the guide here will show you how.
Hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
gizmo4sal3 what is a LCD connecter and a hard reset??????
의 답변
의견 추가하세요
Same thing happened to my Iphone 6 last night with broken home button. You don't have to do any surgery to your iphone, ipod, or ipad. I would suggest you safe yourself the stress, money to repair or troubleshoot and your time. Just let the battery run down on whichever device you are using automatically, if so listen to music on it all day. And when you're charging your device it will continue working normally.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
how would you be able to listen to music , if you cant use your phone?
의 답변
의견 추가하세요
This does not make since the phone is broke duhhh
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Ivan Kennedy Puda 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 42
전체 시간: 6,859
