주요 콘텐츠로 건너뛰기
An upgraded version of the Microsoft Surface, the Microsoft Surface Pro (1514) Laptop/Tablet hybrid is very difficult to open and repair without further breaking the device.
51 질문 전체 보기
open surface pro and change ssd to 256gb ssd
ok after i opened surface pro and with metric duckload glue...... what kind of glue i should use to glue back the screen ?
or do i have to use the same old glue warm it up ? and reglue the screen with ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Heating up and cutting the adhesive will most likely render it useless for resealing the device, so you'll probably want to scrape off the old adhesive with a plastic tool, and use foam double sided tape to reclose the device.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have found that reheating and trying to reuse the old is useless. clean it, get a good 3m double sided adhesive strip set from ebay for like 14 bucks, and do it back together correctly. only way to solve future problems.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
julien v 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 7,616
