주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
Logic Board Upgrade Options for my Replacement?
Hi.
Macbook Pro 13" Model A1278
Two ports are out on my Macbook. Apple says my Logic Board had gone bad, not covered under warrenty.
I am going to replace it myself. Before I buy, I am curious.... if I have to replace anyway, are there any upgrade options? Are there other Logic Boards that will fit in this computer that will make my computer faster?
Thank You,
Bill Valentine
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
Just why is this not covered under warranty?
It has mild water damage that voided the warrenty.
Btw.. I cracked the macbook open last night. I did see the corrosion in one area. The computer works near perfect. One USB port and the Card Reader is dead... Other than that, it's a fine machine. I think I am going to research and try to clean the logic board. Way cheaper than replacing and I am reading about good results.
댓글 달기
답변 2개
선택된 해법
As this model had a low end and a high end option you could fit the higher end logic board into it. In this case the i5 2.5GHz to an i7 2.9GHz based logic board for the same model.
Here's the iFixIt guide MBP 13' logic bd replacement.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
If you have an i5 you should be able to switch to an i7, but check with your vendor that the boards match.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Bob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,856
