screen seems to have dimmed
Hi all,
I am using an Asus G73jh laptop. I was editing a document in word but when wanting to save it, I couldn't. Suddenly I also couldn't select text anymore. The laptop started acting strange so I decided to restart it. After rebooting, it seemed to be working ok again except the screen seems to be dimmer than it normally is. I checked the brightness level and it is at full brightness. I even checked that the brightness could still be adjusted and it could, just not as bright as it should be. Has anyone ever had this problem? I can still use the laptop but it's as if it's in battery saver mode, yet it isn't.
Could there be a problem with the backlighting?
Strange. Hope someone can help. Thanks.
좋은 질문 입니까?
Graham, I suppose your computer was plugged in. Did you already check the power supply (AC adaptor)? Is the computer now running on battery power?
Steffen 의
