Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
865 질문 전체 보기
iPod won't turn on, iTunes doesn't even recognize
My ipod died. Whenever it would crash, I used to be able to recover it and reinstall. But this time...there's no screen, no music and when i connect it to my computer, iTunes doesn't even recognize that it's connected. it's a brick, pretty much. ive tried connecting it, maybe to charge the battery, and after a while it started to feel warm.
anyone have any idea what could be wrong with it?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
3개의 답변
선택된 해법
rtilog, you do want to change your battery first. Follow this guide there is no soldering involved. The toughest part is to be careful around the battery connector. It has the tendency of breaking of the logic board. Use a paperclip and bend it L-shape and hook it under the hold down clasp, then pull straight up. The battery is available right here as well as many other places. Hope this helps, good luck.
iPod Video 30 GB Replacement Battery 이미지
상품
$14.99
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
My suggestion is to change the battery. As I've stated in other threads, when a device won't power on, and heats up when connected to a charger, the battery is usually to blame. Search for your device on ifixit and look through the guides to find the battery replacement guide. The battery is probably pretty cheap, and you won't need to solder.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Generally these power up on the iphone wall charger regardless of a bad battery. I would start off by taking it apart and checking the logic board (the dock connector, as well as the power IC) The power IC is located on the front of the ipod top left corner.
No soldering is required for replacing the battery.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
rtilog 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 11
전체 시간: 1,866
