The power button button cannot be pressed
The power button button cannot be pressed, is need to replace the entire line, or just need to replace promptly? Hope to have the detailed change the power button row line tutorial
좋은 질문 입니까?
좋은 질문 입니까?
Vicky, here is the guide and you can get the part from here. It may of course be possible that you require a new cable, for that follow this guide and a new part from here. Hope this helps, good luck.
안내서
난이도:
어려움
15 - 30 minutes
안내서
난이도:
어려움
1 - 2 hours
해당 답변은 도움이 되었습니까?
I replaced the power button but that doesn't fix the problem. It is still stuck in the depressed position. Does the power cable include the piece that the power button depresses which makes it otherwise function?
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 609
