The 8th and final generation of the Eldorado.
33 질문 전체 보기
Fuel Door - Trunk Releases Sporadic
Cadillac '96 2dr LTD
My fuel door and trunk lid are requiring about 20 attempts to open with both the remote and interior buttons. This began all of a sudden. Anybody know a fix?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
6개의 답변
선택된 해법
My thoughts on this: 1st: how long has it been since you changed your battery in your remote? I find that mine last about a year to two years before having to replace. 2nd: if you do not drive the car much you may have got the lube on the actuators hardened from lack of movement. Re-lubing or greasing them may do wonders. 3rd: how is the charge on the car battery? you may want to put a charger on it to bring it all the way up and see how things are before spending any real time on the problem.
When you use the car switch to open fuel or trunk do you get a click at the unit your trying to open, or is there just no sound except every once in a while. Same question with the remote.
Let us know and we can see if something else comes to mind.
good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Car battery is only a month old. Remote battery is 6 months old. This would not explain the interior button not working. I don't remember ever hearing a sound with either except the sound made when it releases. The car door seems to work fine with the remote. Do you know if these things are electronic or vacuum operated?
의 답변
Questions on the batteries is to establish their health. The releases on the GM's are usually electrical or mechanical. I think yours are both electrical since the engine vacuum would bleed off over a period of time making that type not useful if left for a day or so. I would take a look at the actuator at both the trunk and gas door themselves given the batteries sound like they should be fine. Maybe just manually moving them a few times could help them be more reliable.
의 답변
Looks like the main problem was that I had not been driving it enough.
의 답변
의견 추가하세요
I would look into replacing the relay that moves the electrical signal to the actuators. It may be located in the electrical 'block' under the dash near the brake pedal by all the fuses where all the older GM cars had it, or some probing around the internet leads me to believe there are three fuse boxes located under the hood.
Remember, the switches and remote operate on small amounts of amperage, and they only actuate another switch or relay to get the real power over to the locks. Sounds to me like yours is sticking.
I was able to find a GM door lock relay diagram and there appears to be two relays controlling the actuator. One open, one close.
Here is one of the parts for about 5 bucks
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
hi,while starting my 2002 Eldorodo,i have'd resently experenced the fuel door & the trunk door openning at the same time. what can be causing that. Please Help.. Thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글:
This is a different issue. Please start a new question. Thanks
의 답변
I do have an answer.
의 답변
의견 추가하세요
hi, I have a 02, Eldorado. resently the Fuel Door & The Truck have been openning when starting the car. Never experenced this problem before. Can it be a easy fix? thanks for your Help!!!!!
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
I have a 1999 DeElegance and the problem of the trunk and fuel door opening was tide to the alternator going bad which also drained the battery replace both (they recommend you replace the battery if the alternator goes bad) and never had the problem again. Piece of advice if you replace the alternator and not the battery in about 6months to a year you will be replacing both anyway had to learn the had way hope this helps
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
How do u open gas cap with the string in trunk I pulled it out
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
mayer 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 60
전체 시간: 6,383
