주요 콘텐츠로 건너뛰기
Hewlett-Packard began manufacturing personal laptop computers in 1993.
3332 질문 전체 보기
질문 마감됨
I can't tell where to plug wireless cable in HP Laptop Presario CQ50
Long story short I had to disassemble my laptop. I fuxed all the problems I originally had and now I'm reassembling. I knew this was going to be an issue from the beginning so I only unplugged one of the wireless cables (the longer one with the gold piece at the end) because I had to pull it out before I removed the cover I couldnt see where it goes. I know the general area just not exactly.
Ive only seen this question asked once and even then the answer was "you shouldnt have opened it in the first place"
I have pictures and videos but you cant see where it goes...
its step 10 on this page http://www.insidemylaptop.com/remove-mot...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi, u need to route the cables underneath to the wifi card. There is picture of the wifi card in step 5. There should be two arrows on the card near the connector points. One black and the other one white. The black cable goes to the black connector and the white cable to the white connector. Hope this helps. Write back on what u did. Good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thank you! ^^
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 139
