주요 콘텐츠로 건너뛰기
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
283 질문 전체 보기
How to replace transmission dipstick tube seal
how do i replace the transmission dipstick tube seal on my 1995 chevy suburban?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
2 Comments
My dipstick tube does not have a O ring on the bottom.... I have a 1995 Chevy blazer 4.3
The question I have is the seal or rubber gomlet one time it was leaking at the bottom of the rubber vomit where it is supposed to be flush with the transmission so I took it out redone it and then the second time it was leaking from the top of the rubber grommet where the transmission tube is inserted into the rubber gamut into the transmission help me please I'm like what in the heck???
댓글 달기
답변 2개
선택된 해법
DENNIS, look on the dip stick tube. There should be a mounting bracket with one mounting bolt. It should be a 10mm bolt, remove that. The dipstick tube should just pull out of the transmission. You may have to twist it hard a couple of times. Even so it is a simple pressfit, it may still be pretty tight and may need some "convincing" to be removed. When replacing the old dipstick tube there is an O-ring on the the bottom, about 1 inch up from the end. Use some RTV sealant on that O-ring before installing it back onto the transmission. I also find that it helps to place the new tube in the freezer until you are ready to install it. This will contract the tube slightly and will make it easier to reinstall. The pressfit and the small bracket are enough to hold the tube in place. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 5
4 Comments:
How to take a transmission dip stick off
David Charlton remove the bolt from the mounting bracket. The tube itself is just a pressfit. you should just have to pull it out.
Just replace flex plate in a 1998 GMC Yukon. Every thing is back together but the transmission filler tube will not line up on the stud from the transmission to engine. Tube is all the way seated but the hole is above the stud. When we unbolted it, it just came right off. Took a few colorful word but we got it out.
I would imagine the bracket got bent slightly while taking it out aftwr you got it unbolted. If you are sure it is all the way installed then push the bracket so that ot li es up and the bolt can be installed and tightened.
댓글 달기
Where does the bracket attach? I have recently become a 4th gen Chevy pickup onwer. I noticed that it would leak ATF when parked facing down hill. Found it was the seal you folks are talking about. Then realized the tube was not attached. I can't seem to find where the 10mm bolt goes to attach said tube. Any help would be appreciated.
해당 답변은 도움이 되었습니까?
점수 1
2 Comments:
Did you find anything out I'm having the same problem
@Josh Reed make/model/engine of your vehicle?
댓글 달기
귀하의 답변을 추가하세요
DENNIS 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 53
30일 전: 272
전체 시간: 31,426
