주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
질문 마감됨
Touch not working even after replace with new screen for iPhone 4
I do replace screens lot times so i am not bigginer.
I have a iphone 4 gsm usa at&t model, suddenly not response to touch at all. so i think touch connector might be loose. but it was good connected. so i try to replace new screen but when i connect new screen with same iphone. it still not working. I try to use both screen to other iphone and both screen working good.
So what i understand is problem is motherboard bcoz charging port also looks good to me and iphone is not water damage.
is any body know solution. iphone is not in warranty.
I done restone in itunes. i done pressing both button trick so many times. but not working
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
If both screens work on a different phone, then most likely it is the logic board. Sometimes the connectors on the motherboard just stop working for whatever reason.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 417
