iPad 1 Black tiny oval blocks inside
I took apart my first iPad 1. About 18 plastic pieces fell out. They are oval in shape. About 3/8" long, 3/16" wide and 1/8" thick. Any idea what they do and where they go.
Thanks
좋은 질문 입니까?
Thanks
좋은 질문 입니까?
There are little foam blocks that keep the display assembly snug to the frame circled in the pic below. 18 sounds like a lot though.
Other than that, if they are little square metal pieces they are likely the tabs from the bezel on the digitizer. Most of them, unless you are SUPER careful, will break off when you pull the screen out. When you get a new bezel/digitizer (I hope there was something wrong with the old one, which is why you took it apart) it should have fresh metal tabs on it.
Let me know if that helps.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 190
