Screen not working, black
Hi,
My imac A1207 20" screen is just black.
In a previous replacement of the cdrom I brake the siplzy cable and it worked badly, showing horizontal lines and a 256 color display.
After replacing the cable, I just dont have any image. I can only note that #1, 2 and #3 leds are grren solid and when I put the imac to sleep the #3 led goes off while the other two keeps on.
I really need this not so new machine to work. Any clue?
좋은 질문 입니까?
댓글 4개
really need help here... connecting an external pc screen doesn't give me any image, just the 'no video' signal. I dunno if in order to use an external monitor I have to do anything more than just connect it.
mjm 의
Ouch! thats not good! - IF you can't get an external display working then the GPU unit is damaged.
Dan 의
Dunno how can happend, the inverser cables are ok as I can see, and just when realising the display cable was broken the image where bad but it was a image... I think there is also some back light....
mjm 의
I'm having the same problem. with 2 separate iMac 20" desktops. neither one will put a display up, but the iMac recognized that an eternal monitor is connected.
tpzid53 의
