Sal Torre, since you are getting the right POST beep code, I would try this next :"try this:"Certain changes in BIOS settings (such as chipset timing or latency, memory timing or latency, processor clock frequency, etc.) can cause a system to no longer boot.
If you are able to enter the BIOS Setup by pressing F2, reset the BIOS to factory defaults by pressing F9. Save and exit the BIOS Setup.
If you cannot enter the BIOS Setup, clear the CMOS:
Turn off all peripheral devices connected to the computer.
Disconnect the computer’s power cord from the AC power source (wall outlet or power adapter).
Remove the computer cover.
Locate the battery on the board.
With a medium flat-bladed screwdriver, gently pry the battery free from its connector. Note the orientation of the “+” and “-” on the battery.
Wait one hour then replace the battery.
Replace the computer cover.
Plug the computer and all devices back in.
You may also need to perform a BIOS Recovery after clearing the CMOS." from here with more info about your motherboard.
댓글 9개
Pull your RAM and see if you get a POST beep when you restart your computer. You should hear three distinct beeps.
oldturkey03 의
Yes I get three beeps
Sal Torre 의
Thats good! so your logic board sounds OK (getting Power)
Dan 의
I don't see how changing the paste can cause it to not work
Sal Torre 의
most likely not the thermal paste. Is this the same computer you had trouble with before Pc will not boot up
oldturkey03 의
댓글 4개 더보기
