주요 콘텐츠로 건너뛰기
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 질문 전체 보기
Is it possible to reinstall digitizer without damaging it?
I know that the digitizer of an Ipad 2 has been glued to the case with adhesive tape, and that you need a hairdryer or heatgun to soften the adhesive, to get it removed more easily.
I know you need to remove it, for example to replace the battery.
Is to possible to remove the digitizer without damaging it and to reinstall it later ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Yes, it's absolutely possible. I've done more than 300 iPads that came with Dock Connector issue because the battery didn't get charged. The main iPad 2 flaw is that Apple's engineers failed the exact measurement of the dock connector cable to its logic board port. Being a few millimeters long length of the dock connector ribbon cable, it simply plugs out over any accidental fall or bump. Not the case always but to many many iPad, it happens. It's because the stiff dock connector ribbon cable is bent on its assembly due to extra millimeters length and it produces strong upthrust pressure on bumps. And the cable gets disconnected. So the iPad comes as dead not getting it battery charged. A lot of people have misconception about dead battery and customers are charged a lot on battery replacement during which, the dock connector is plugged back obviously. Actually, Apple was supposed to recall iPad 2 due to its manufacturing flaw, but nobody has raised voice until now. Probably, I'm the first tech to notice it and discuss openly in this community. Hope somebody helps this ahead.
Anyway, in your context, whatsoever is the reason of opening your iPad 2, you can simply open it without any use of heat-gun or specific tool. Simply, get the thinnest and the most stiff Guitar Pick possible. You can get few of them from any music store in a dollar or less. Insert it first from the lower right corner next to Home button. Keep peeling off the edge taking enough time and not prying. Prying attempt by raising one side of the pick breaks the glass easily. A lot of people make mistake here. Keep peeling ahead in a parallel approach. Be careful just above the volume controls because there is a cable trapped between digitizer and frame. If it's a Cellular model, try to be careful peeling to the top of the iPad on the left side of the power button as well. And pay attention to the left lower corner where there is digitizer cable trapped between digitizer and the frame.
You may follow the take apart guide and use guitar pick to get the screen out safely. This is kinda interesting. Hard you may feel because it's your first time, but as you do several of them, it's fun. And you gonna say how funny was the idea of adhesive Apple chose to wrap up iPads! In this process, the best thing is: you don't have to use any alternative adhesive. The same one works fantastic. Just be careful not to touch over the adhesive with your oily fingers. You may also keep it free of dust while working on.
Good luck.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thanks a lot.
I went to the guitar store and bought the most thinnest plectrum, and did the job perfectly in just 5 minutes ! for the first time. Almost perfectly, I cut through the digitizer cable on the left side of the ipad 2.
But learned a lot, all the adhesive stayed on the digitizer/glass part and I could close the ipad 2 perfectly as if I never opened it.
댓글 달기
I just saw my post again and in the meantime I made a video about it, here you can see it:
https://www.youtube.com/watch?v=SAeyzEdn...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ProConsoles 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 537
