주요 콘텐츠로 건너뛰기
1.86GHz 또는 2.13GHz 프로세서, 128GB 또는 256GB 플래시 저장공간
147 질문 전체 보기
Is there any way to repair a broken (ripped) fan connector
Hello everyone,
The title is pretty much self-sufficient.
More precisely: when trying to clean the dust in my MacBook Air 13" (late 2010 model), I stupidly destroyed the fan connector for the fan. And by destroyed, I alas really mean it: two of the pins have been ripped away (only soldering points remain)!
Is there any chance to fix this, without having to change the whole logic board?
Edit: here are some photos of the broken connector; they are of poor quality, but they should nonetheless show you the problem...
Edit2: Agh, I knew these crappy photos wouldn't do. I managed to make some better shots with a borrowed camera:
You can compare it with the normal state of the connector herafter (from the photo of step 6 of the "MBA 13inch 2010 replacement for logic board" guide) to see what it should be like...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
Kevin, it might be possible to resolder it, or a replacement, but to be for sure, it might help if you post an image of your damage with your question. Use this guide Adding images to an existing answer to add images to your question.
Hello oldturkey,
I joined some (poor) photos of the broken connector. I have no access to a real camera, so I had to take them with some mobile phone...
댓글 달기
답변 2개
선택된 답변
Kevin, that actually looks pretty good. Thanks for posting the images.
Edit
Looks like I got the pics mixed up:-) okay, your solder pads still look good and your traces are okay, which is great. It is your connector that is definitely in need of replacement. I think if we can find a replacement for that, you can solder it back on, of course you will need to have some good tools and good skills to do that. But, overall I think this is doable. Looks like the connector is available at places like this. I will start looking for a proper connector and keep you informed. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Ah, but it is not this connector that is broken (this one connects to the I/O board, and AFAIK it is just fine).
I knew my crappy photos weren't clear enough... I have uploaded a couple of better ones, and as you will be able to see, it is not nearly as good: half of the pins are just gone.
Hello oldturkey.
Thanks for your answer. Did you find a way for me to get a suitable replacement connector?
Kevin did you check on the above link in my answer http://www.amazon.com/CyberDoc-LLC-conne...
댓글 달기
If the soldering pad remains, it is easy to fix. Just solder a new one onto it. If the pad is ripped off, you're in deep trouble.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
One of the images posted shows the solder pad's are in decent condition. We are still trying to find a new connector.....:-)
댓글 달기
귀하의 답변을 추가하세요
Kevin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 904
