How is the home button attached to the motherboard?
I lost the home button bracket when I was replacing the digitizer. I'm looking to replace it, but I just can't figure out how it's attached to the motherboard of the ipad.
좋은 질문 입니까?
좋은 질문 입니까?
Its not. It is a separate piece that gets transferred from the original to the new glass when replacing the digitizer. If you have lost the bracket, it would NORMALLY be attached to the OLD glass. It is a large black metal bracket, with 2 copper contact points.
http://www.ebay.com/itm/BRAND-NEW-HOME-B...
This is an example of what you need to purchase in order to complete your ipad.
Good luck
해당 답변은 도움이 되었습니까?
So the copper contact points are when makes it work?
It's contacted with the new digitizer?
The copper points are for the button yes. When you align the button on your glass the copper points need to be touching the metal to allow it to create the correct connection.
flogo2003 is correct.
I would add that the two copper points touch two prongs that are attached to the sync port. The sync port is plugged into the motherboard. So, technically, the home button operates independently of the digitizer. It is just attached to the digitizer with adhesive for functionality and aesthetics.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 271
