Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1960 질문 전체 보기
My phone will not charge...
wont charge on usb or sync to ncomputer...when plugged to computer it pings n nothing else
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
2개의 답변
선택된 해법
debbie bennett, try a different cable, a different USB port, and an AC adapter and see if that makes a difference. Check your dock connector for any bend, broken or corroded pins, clean it with some isopropyl alcohol and a few puffs of compressed air. If none of that makes a difference, replace the battery before anything else. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
It could be a dock connector problem or a logic board problem.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
debbie bennett 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 97
