주요 콘텐츠로 건너뛰기
Power Macintosh G4는 Apple이 1999년에 출시하고 2004년까지 판매한 일련의 개인용 데스크톱 컴퓨터입니다.이 페이지는 M5183에 한정됩니다.
39 질문 전체 보기
Why does this computer not power up at all?
I have replaced the pram battery, power supply, and switch on this PowerMac G4 450 Mhz dual processor computer and still no power. Will a new logic board assure a fix or could it be the computer processor, ribbon cables, etc. causing this? I don't want to sink much more into this unless it is a pretty sure fix. Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
ndwig , here is the way Apple suggest that you check this particular symptom:"
System is completely dead (no fan movement and power LED is not lit)
1. Verify the power outlet is good.
2. Replace the power cord.
3. Make sure the voltage switch on the back of the power supply is set to the correct
voltage.
4. Reset the logic board. Refer to “Resetting the PMU on the Logic Board” in this
chapter.
5. Check for trickle voltage on the power supply connector. Refer to “Power Supply
Verification” in this chapter. If verification fails, replace the power supply.
6. Disconnect external devices, including the monitor, and start up the computer.
7. Remove internal cards and start up the computer.
8. Disconnect internal hard drives from the logic board and start up the computer.
9. Check the modem connector. If the connector has any bent pins, replace the logic
board.
10. Check the pins in the power supply connector on the logic board. If the pins are bent,
replace the logic board.
11. Replace the logic board.
Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks. I'm pretty much to the logic board part of this.
댓글 달기
Check and see if your CPU is switched to on
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
@Mason Schmidgall, how do you switch the CPU to on?
Thanks for your input. I use the power button on the front of the machine try and power it up. There was a storm that put the power off here for just a few minutes. Ever since then the computer has not responded at all.
댓글 달기
귀하의 답변을 추가하세요
ndwig 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 607
