주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Weak antenna signal after replacing home button
Hi all,
I did replace the home button of my iPhone 4 home button since it was not working. After reassembly of the phone, I noticed that sim antenna signal is much weaker than before. Everything else looks to be fine, the WiFi is also ok.
For example when I am inside the house the signal strength is quite low and disconnects time to time. It was not like this before. Out side I used to get full coverage but its not full coverage now.
Can you please tell me what would be the problem and how can I fix this issue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Have you tried calling your cell provider and explaining to them? Sometimes the signal strength can be attributed to a down tower or your phone may need a location update. I have had to do this before. Takes a minute to do but sometimes fixes connection and signal issues. Good Luck!
Update
All I can say is I moved and my signal dropped off. I called the cell provider and told them and they had me do something to my phone and make sure I had correct version of software and my signal increased to full scale. Just a suggestion.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Well I can ask people around to see if that's the problem. But I highly doubt this.
Do you by any chance remember what you did?
I called Verizon which is my provider and told them and they sent something to my phone and I restarted the phone. I think what it is you are given a base tower that all of your calls go through and when you move you may be closer to another tower. It could just be a Verizon thing or I could be assuming something. I deduced this from hearing others complain about this before and getting tidbits of their conversations with Verizon. I can't be sure because I didn't actually ask them when I called. If I get a chance I will call tonight and ask them what they did...providing they will tell me! Who is your provider?
Won't hurt to ask them in any case!
댓글 달기
귀하의 답변을 추가하세요
Sean 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 157
