주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
Phone shows plug into iTunes
Screen shows that I have to plug my phone onto iTunes and it will not do anything els please help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 3개
What happens when you plug it in? Did anything happen to phone? did this just start? Give us some more info.
I reset the phone and this has just come up
How did you reset this phone?
댓글 달기
답변 3개
가장 유용한 답변
Hello, (Please read full answer before attempting).
Please try plugging the iPod into your Computer and loading up iTunes, A window should then pop up saying that your iPhone is in recovery mode or just that it needs to be restored before you can use it. Proceed to restore the iPhone.
It can take a while so do not be tempted into resetting it during the Restore as this causes the Connect to iTunes page to appear again and is sometimes irreversible with iPhones when the restore is interrupted.
If the restore works then your phone should be back up and running, if not then load up iTunes again and it will say restore unsuccessful and will give you an error code. If the restore did not work please comment the error code and we will go from there :)
Sadly I do not think you can back up the data before hand and the iPhone is failing to start so needs the software reinstalling or hardware replacing.
Please comment your results :)
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Hi there my iphone 3g has been out of action for a while as its been saying connect to itunes for nearly two years everytime I try recover my phone it doesnt work please help !!
Eror code: 1015
댓글 달기
In this situation, it indeed indicates that you have been stuck on recovery mode screen. The intuitive description is iPhone display with USB icon and iTunes logo, you can easily and quickly fix this with a free and excellent program named ReiBoot provided by Tenorshare. Have a try.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
are you able to do it for me ?
um the software you mentioned (reiboot) is not free, in order to do anything with it it ass you to register and pay a minimum of 35 dollars!!!!!!! :(
댓글 달기
I hv the same problem with my iphone 3g
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Craig Joyce 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 7,752
