주요 콘텐츠로 건너뛰기
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
225 질문 전체 보기
hard drive upgrade to newer type
i have an iPod 4th Generation or Photo and
i wanted to know if it was possible to use a new type of hard drive with the ipod and still have it work. i saw this toshiba one but am not sure if it needs to be the hard drive specifically made for that ipod in order to work.
http://www.geeks.com/details.asp?InvtId=...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
가장 유용한 답변
brandon, , the drive you picked does notwork. The interface is wrong. Your model iPod uses a ATA-6 interface with pins, not a ZIF socket. I believe that a Toshiba MK8007GAH 80 GB would be a good choice for this iPod. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
thanks for the help :D
Thank you for accepting my answer. Best of luck to you.
I've upgraded mine to a Toshiba model MK8007GAH that works great. Now I'm thinking of trying a Kingspec 120GB ssd http://www.amazon.com/128GB-KingSpec-1-8...
Update: I have installed the Kingspec 128GB 50-pin SSD into a 4G ipod and it works great so far.
댓글 달기
My 20gb 4th Gen iDie Hard Color, model A1099, lost his mind after I dropped it from 2+mtr high on a concrete floor. I ordered a:
64GB KingSpec 1.8-inch IDE CF 50-pin SSD Solid State Disk (MLC)
to replace the original KIA 20gb HDD. Within 24hrs I received the 64gb KingSpec SSD.
I used iFixit's "iPod 4th Generation or Photo Hard Drive Replacement" as my DIY guide.
A good thing to know is that the 64gb KingSpec SSD has the same size as the original 20gb HDD so you don't have to buy a 40/60gb thick rear panel, 40/60gb headphone jack or bracket. Connecting the KingSpec SSD is exactly the same as connecting a HDD
When I was done I attached the iMod to my Laptop. Right after that I got a "iPod Firewire AC Charger" logo on my iMod screen. When I attached it to the AC Charger the "iPod Firewire AC Charger" logo disappeared and the "battery is fully charged" logo appeared. Right after that I connected my iMod again to my laptop. Because iTunes recognized the iMod it started itself up. After I choose "Restore iPod" in iTunes my iMod was within one minute fully functional again. Time will tell if it became a "iDie Harder" ;-)
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
이 답변은 원래 다른 질문의 답변입니다.
I recommend just buying one from iFixit.
http://www.ifixit.com/iPod-Parts/iPod-4t...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
brandon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 299
