주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Can't hear caller. Caller can't hear me. Skype Works?!
Intro:
Alright, I'm calling it quits.
I've been fixing iPhones for a little over a year now and have never ran into this problem.
The phone was dropped with the back shattering.
The Problem:
When placing calls, I can't hear anything. The other caller can't hear me. THE LOUDSPEAKER does not work. Using brand new EarBuds does not work.
However, when using Skype, everything works perfectly. When playing music, the loudspeaker works. Headphones work, however, the controls do not work. VOICE MEMO works perfectly.
The Failed Fix Attempts:
1.) Freshly upgraded to 6.1.3
2.) Pressing corners to check for loose connections.
3.) Cardboard Method: Placing a piece of cardboard over connector.
4.) Paper Method: Placing a stack of papers underneath WiFi metal plate.
Any advice is greatly appreciated.
Thanks,
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
I have 3 solutions
this works on Iphone 4
i have tested all 3 of them, and have had success with all 3 solutions..
The Problem:
Iphone 4 lower microphone stops working.
recording video and memos works fine, but people cant hear me during calls.
just to clear things up for everyone...
when using video recording, memos or anthing else that can record your voice, the iphone is using the TOP MICROPHONE.
when calling/getting calls the iphone will be using the LOWER MICROPHONE.
When you put it on "Speaker" then the phone will use both.
Solution 1:
Change the Dock Connector
if that wont work... then....
Solution 2:
Click on this link, and follow the instructions, on how to fix the Compiler Chip.
iPhone audio problem: fixing an audio compiler chip fault
sounds and looks wierd...., but yes it works....
done it with multiple phones so far...
if solution 1 does not fix the problem, then solution 2 should help allot.....
should the problem still persist, then you might have a problem with your Home button.
See Solution 3 for more info
Solution 3:
Change the Home button.
this last solution was the problem solver for me... i had 7 dock connecters, new and from other broken phones i tested with.
in the end, the home button just gave up when i was swapping around, then i just replaced it, and Voila.... my microphone was working again, and my home button was working too :D
i cant really explain what really happend, but its my 4th iphone i have had these problems with, and all has been repaired with these 3 simple solutions...
i really hope it can help alot of people in here, with issues with iphone 4 microphones not working
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Had a similiar problem with my iphone 4s the phone AUDIO CHIP IS !@#$%^>>>you need to replace it...
NO SOUND FROM HEADPHONE NO SOUND FROM EARPIECE NO SOUND FROM SPEAKER THAT IS THE AUDIO ICU CHIP >>>NEED REPLACEMENT
Or you can try the following fix here:
http://www.youtube.com/watch?v=DPR8qrAcg...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
My caller can't hear me ,i can't hear my caller thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
iPhoneProbs 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 9,826
